- This topic has 7 replies, 3 voices, and was last updated 6 years, 4 months ago by
Yuri Kovelenov.
2018-06-16 at 9:23 pm #5089
Viktor.Rios
ParticipantFor this question, imagine I got a 6-faced (cube) object containing numbers 1-6 on each face.
How can I setup a puzzle so that it will tween the camera between the current position and a position facing directly towards FACE 1?
Or say I´m viewing face 4, and I want it to tween to face 6 (on direct opposite to that face of the cube). I know I need a trigger (for example, clicking on an annotation) but then how do I make the camera go “around” the cube to tween to the next “view”? I´d like to view different faces of the cube with the tweening transition.How possible is it to make it tween to “another object” (like a hidden null) and THEN go to to the next “face” view on the cube?
Thanks.2018-06-18 at 8:23 am #5107Mikhail Luzyanin
StaffOr say I´m viewing face 4, and I want it to tween to face 6 (on direct opposite to that face of the cube). I know I need a trigger (for example, clicking on an annotation) but then how do I make the camera go “around” the cube to tween to the next “view”? I´d like to view different faces of the cube with the tweening transition.
You can place an Empty/Dummy object in front of each face of the cube and twiit camera to it. What version of Verge3D do you use? 3ds Max or Blender? I can make an example for you but don’t know which software to use.:)
2018-06-28 at 1:58 pm #5298Viktor.Rios
ParticipantHi, thank you for your reply. I´m using Verge 3D on Blender. Yes, an example would be very helpful. Cheers.
2018-06-28 at 3:00 pm #5303Mikhail Luzyanin
StaffHi, thank you for your reply. I´m using Verge 3D on Blender. Yes, an example would be very helpful. Cheers.
Here’s an example for you. It’s not exctly what you want I made each cube face as button, but you can make as clickable object any you like event html button.
2018-10-29 at 10:54 pm #8513Viktor.Rios
ParticipantWhen I click on any face color of the cube, on the file you sent: What is suppossed to happen? I click and nothing happens, and there´s no status or anything.
2018-10-30 at 7:30 am #8517Mikhail Luzyanin
StaffWhen I click on any face color of the cube, on the file you sent: What is suppossed to happen? I click and nothing happens, and there´s no status or anything.
Must happen something like this. May be you run pure gltf not an html file?
2018-11-04 at 4:05 am #8634Viktor.Rios
ParticipantI think I need to update my june 2018 download from Verge 3D into the latest modules. I think that’s the reason. Let me try again.
2018-11-05 at 10:37 am #8642Yuri Kovelenov
Staff -
