tutorials on adding custom javascript
Home Forums Programming tutorials on adding custom javascript
  • #30886
    g_hug
    I know there is a description of the various ways to add javascript, but a walk through example would be really helpful to non-programmers! Is it something the Verge3D team would consider or other more knowledgeable users that myself?
    Can any javascript library be added to verge3d script?
    The code examples given here are html, how to incorporate them into the .js file? Also, they seem the same as three.js examples, would it be possible to incorporate three.js code directly?
    Equally, is it possible to add howler.js for ‘spatialised’ sound using a webaudio API?
    Apologies for glaring lack of knowledge here! Am trying to work out what is possible for me to teach myself and also how to extend the possibilities of the app beyond current existing puzzles.
    Thank you
    #30888
    Sure, there are no obstacles to do so!
    That is a non-trivial task and requires certain coding skills to perform, which may be difficult for a non-coder, sorry. But it is surely possible, and you kind find somebody here on the forums to help you (or request a feature from us).
    yes, in most cases three.js code should work with Verge3D
    Of course, I’m sure it is possible.
