Turn off VR and AR buttons?
Home Forums Puzzles Turn off VR and AR buttons?
  • #35341
    jaspixel
    I am testing my project on various mobile devices and a lot of iPhones automatically show the VR and AR buttons which I don’t want showing.
    Can you tell me how to disable these please?
    Many thanks,
    Jas
    #35364
    Hi Jas,
    can you share a link to your application so that we test it out on our devices? Or may be a screenshot.
    #35373
    jaspixel
    Thanks Yuri,
    It if not for publication, can I email the link to you separately please?
    Which email should I use?
    Thanks
    Jas
    #35376
    Thanks for sharing the link (great job BTW). I used Chrome Dev tools to inspect the loaded files and found that you enabled the AR/VR compatibility module at application startup. If you don’t need AR/VR in your app you can remove the link to this .js module from your .html file (as a workaround – I’m still unsure why it shows those buttons and I was not able to load your app on my iPhone at all).
    You might also check your textures – it looks like the same files are loaded twice each. This may be due to the fact that you use different Blender images that load the same image file. May be this will help with iPhones too.
