Home › Forums › Programming › Trying to add lensflare into myapp.js
- This topic has 7 replies, 3 voices, and was last updated 4 years, 8 months ago by
Alexander Kovelenov.
2020-07-21 at 12:43 pm #30403
core3d
CustomerHi,
I’m not a programmer but i’m trying to get work lensflare example. In run code section i add lensflare example code but i get “Uncaught ReferenceError: Lensflare is not defined” error.
Then i realize i need to import Lensflare.js file and i get “Uncaught SyntaxError: Cannot use import statement outside a module”.
Then i tried to add it with <script type=”module”> but it cannot works either.So how can i add Lensflare.js script to my app?
2020-07-21 at 1:02 pm #30406Yuri Kovelenov
StaffHi,
you can edit your_app_name.html file. In its header, there are some scripts tags. You need to add another script tag for your js file.
2020-07-21 at 1:15 pm #30414core3d
CustomerI already tried that but still same error…
<script src="v3d.js"></script> <script src="myapp.js"></script> <script src="Lensflare.js"></script>
then i add this:
function runCode(app) { // add your code here, e.g. console.log('Hello, World!'); import { Lensflare, LensflareElement } from 'Lensflare.js'; var textureLoader = new v3d.TextureLoader(); var lensflare = new Lensflare(); var textureFlare0 = textureLoader.load('textures/lensflare/lensflare0.png'); var textureFlare3 = textureLoader.load('textures/lensflare/lensflare3.png'); addLight(0.55, 0.9, 0.5, 5000, 0, - 1000); addLight(0.08, 0.8, 0.5, 0, 0, - 1000); addLight(0.995, 0.5, 0.9, 5000, 5000, - 1000); function addLight(h, s, l, x, y, z) { var light = new v3d.PointLight(0xffffff, 1.5, 2000); light.color.setHSL(h, s, l); light.position.set(x, y, z); lensflare.addElement(new LensflareElement(textureFlare0, 700, 0, light.color)); lensflare.addElement(new LensflareElement(textureFlare3, 60, 0.6)); lensflare.addElement(new LensflareElement(textureFlare3, 70, 0.7)); lensflare.addElement(new LensflareElement(textureFlare3, 120, 0.9)); lensflare.addElement(new LensflareElement(textureFlare3, 70, 1)); light.add(lensflare); }
run code section can recognize another js file?
2020-07-21 at 1:51 pm #30416Yuri Kovelenov
Staff2020-07-21 at 2:00 pm #30417core3d
CustomerWhen i remove it i get: “Uncaught ReferenceError: Lensflare is not defined” error.
2020-07-21 at 2:03 pm #30418Yuri Kovelenov
Staff2020-07-21 at 2:58 pm #30420core3d
Customerunfortunately same error… “Uncaught ReferenceError: Lensflare is not defined”
using this: lensflare.js2020-07-21 at 5:14 pm #30431Alexander Kovelenov
StaffHi,
in order to use modules you should define your main js file in the HTML as of type module:
<script type="module" src="your_app.js"></script>
Then, import your assets globally, not in the runCode() method:
'use strict'; import { Lensflare, LensflareElement } from './Lensflare.js'; // rest of the main JS file ....
