Triggering Normal Map Puzzle Multiple Times Crashes The Scene
Home Forums Puzzles Triggering Normal Map Puzzle Multiple Times Crashes The Scene
  • #19887
    hoody
    Hey Guys i implemented the Generate Normalmap puzzle for a texture from text.
    This works – but if i update my text (normal map gets updatetd too) -> my console shows me every time: Verge3D 2.15.0 pre1 (WebGL 1.0)
    After updateing the text for the thrid or fourth time , the whole scene crahses – it it says in the console: v3d.WebGLRenderer: Context Lost.
    If i deactivate the normal map puzzle: i can update the text as often as i want without crashing the scene.
    I really cant tell whats the problem.
    Heres my puzzle setup:
    #19903
    Verge3D 2.15.0 pre1
    the stable version is out – might want to update!
    Looks like you are creating big textures and hitting GPU memory limit. We’ll investigate if it is possible to free memory from created textures. Thank you for reporting this!
    #19909
    it’s highly possible you have a memory issue. The 2860×1445 size is quite big for the textures. Also, this size is not recommended for interactive 3D. You better try something like 2048×1024 or similar (256,512,1024,2048 width/height values are OK).
    X | FB | LinkedIn
    #19943
    hoody
    Hey Alex. I reduced the size to 2048×1024 as you recommended. Thats a good idea, but it will not solve the problem, that the puzzle is triggered multiple times.
    #20614
    hoody
    Hi Yuri. I hope you are doing weill. Do you have any news on this issue? Im almost done with my first demo and the last thing thats bothering me is this problem.
    In my case the generate normal map puzzle in combination with texture from text puzzle is kind of useless if it cant be triggered more than 2 oder 3 times.
    It would be awesome if there was some kind of fix for this!
    Thanks
    #20618
    We created a task in our dev tracker. Hopefully we’ll investigate this issue soon.
    UPDATE: we managed to fix that. The fix will land in the next Verge3D update.
