transparent material 3ds max
Home Forums General Questions transparent material 3ds max
  • #36985
    andreabianchi22
    I have a problem in 3ds max with transparent physical material,in the attached screenshot, you can see a transparent package, the blue pattern (made with opacity map) should be on the back so I put it behind but it looks like it is onfront. I set thin-walled, alpha blend, no depht-write , rendering order 4 and I use an opacity map (for the pattern) and a normal bump for the plastic in order to see the seams. How can I fix the problem?
    Thank you very much.
    Good new year (and sorry for my bad english)
    #37010
    Hi! Happy new year!
    You might try to divide the transparent parts into different meshes/materials and play with rendering order setting for these parts.
    There is no polygon sorting inside a single mesh/material and this may cause issues in real-time graphics.
