transparent cube under object in AR
Home Forums General Questions transparent cube under object in AR
Viewing 1 post (of 1 total)
  • #67688
    vision
    I want to have my object floating the air 1 meter above the floor.
    A transparent cube below the object I thought is maybe a solution. But this is only partly working. The cube is lifting the object, but only to around 30cm.
    When I make the transparent cube higer, still the object is floating at around 30cm.
    Any tips to get it to 1 meter?
