Transparency of 1 rendering white
Home Forums Graphics / 3ds Max Transparency of 1 rendering white
  • #24552
    web
    I trying to fadeout out geometry. I added a controller for the transparency of the material and checked “thin-walled”. When I now set the transparency to 1 the object is rendering as pure white.
    What am I doing wrong?
    #24555
    does it work properly without “thin-walled”?
    #24558
    web
    Nope, then its just black.
    Did some further testing. When I set transparency directly in the material without a controller the objects is transparent like it should be.
    When I control the transparency via a linear float controller and setting the value via puzzle, its not working anymore. When fully transparent the object gets the backgroundcolor.
    #24567
    can you share a screenshot of your material setup? and puzzles
    #24573
    GLiFTeK
    Do you have MANY transparent materials going on? Too many can cause issues.
    #24797
    web
    I found the issue. When the material doesnt have transparency initially set I get this error. When the transparency is set for example to 0.01. Then the transparency can be set via puzzle properly.
    Is this a bug or a feature? When its a feature how can I fix that behavior?
    #24804
    you may have Auto enabled for transparency. This means that if transparency is not set, the material is considered as opaque.
    https://www.soft8soft.com/docs/manual/en/max/Transparency.html
    Just make it Blend, for example.
