Three.js Base Library Updates
Home Forums General Questions Three.js Base Library Updates
  • #29022
    shantiscript
    Hi guys,
    I wanted to ask if you are constantly updating the Verge3D base v3d.js when new versions of three.js are released or if you are just running your own releases independent of three.js updates.
    I am asking because i would like to understand if I will be able to use updates in three.js also in verge or if will need to work on separate codebases in the future if i would want to use features added to new three.js releases.
    Kind Regards
    Sebastian
    :bye:
    #29028
    Merging Three.js features requires a LOT of work since there are many differences between the two code bases. That’s why we do it from time to time, approximately at half-year intervals. The last sync milestone was Three.js r113, but if you need something from Three.js r114 or above let us know, we’ll do the upcoming synchronization sooner than later.
    Best regards,
    Alexander
    X | FB | LinkedIn
    #29107
    shantiscript
    Hi Alexander,
    at the moment i don’t need anything specific from the newer versions. I just wanted to figure out if you keep the base up to date so we can make an informed choice for our dev stack. Its good news for us that you do!!!!!
    Thanks and best regards
    Sebastian
