The simple way to make the HIGHLIGHT Effect?
Home Forums General Questions The simple way to make the HIGHLIGHT Effect?
  • #6591
    justkmoo
    I just want to highlight an object when I click it. Is there a simple way to make an effect like this(not the outline effect):
    null
    #6594
    It’s possible to achieve only using amterial node animation, for example mixing material and pure color before output node mixing it with mix node and using animated Value node ad value for mix node. If you using Cycles nodes you will need to mix your material with emittion BSDF before output to get pure color.
    #6595
    justkmoo
    Thank you Mikhail!
    Now I see how you guys make the e-learning project.
    It will be great if you could make the highlight effect into a puzzle like the outline’s. :)
    #6596
    You can make it inside node material and run using puzzles;).
