The problem of the animation of excavator‘s wheel rotation
Home Forums General Questions The problem of the animation of excavator‘s wheel rotation
  • #21454
    karl36
    Hi,I make the project of excavator. It contains some rigs and animation. I want to the excavator’s moving with the wheel’s rotation. And it works ok on blender2_8. When I use the “Sneak Peek”,wheels don’t rotate and just move. Where did I do wrong?
    #21461
    Will work only only direct animation of the object’s and bones, not constrain parameters. If it’s armature you need to set Bake Armature Action and it can help. If it’s object animation you need to redo all animation as animation of position, rotation and scaling of the objects or bake all manualy.
    #21465
    karl36
    Sorry,I don’t learn how to bake the armature actions.If make sure that the tab is selected, the animation will be OK.
