Textures with transparency?
Home Forums Graphics / Blender Textures with transparency?
  • #6489
    BrianMZ
    I’m trying to use an image texture (png with alpha) on a simple plane. The areas that should be transparent are showing up black. What is the best/simplest way?
    Thank you.
    #6490
    You need also enable Transparency chackbox in the material settings.
    #6493
    BrianMZ
    Perfect! Thank you. I was trying to make it work in the texture panel.
    #15174
    tomcd
    Dear Developer,
    I have the same problem but cannot fix after ticking those 2 boxes. When view in view port texture mode and render in Blender Render it looks okay! When I click “sneak Peek” it shows a white background. Could you please help? I have attached the blender file. Thank you!
    Best Wishes,
    Tom
    #15177
    You better create a node material using Blender Internal nodes, but even better to use Cycles or EEVEE, because I think Blender Internal will be no more supported by the new version of Verge3D engine when 2.8 will be released.
    #15234
    Crunch
    Tomcd, this discussion started back in August of 2018 so the screenshot Mikhail had posted was from an earlier version of Blender. In blender 2.8, I switch the blend mode to “alpha clip” in the material settings (see screen shot)
    I am not sure if this is the right way to do it but it works.
