Texture channel not working
Home Forums Graphics / 3ds Max Texture channel not working
  • #21631
    mugga
    Hello,
    I got some custom uv’s on a different texture channel. Sadly verge isnt using the specified texture channel I’m setting in the bitmap. Is there any trick? Or does verge simply ignore all channels except channel 1?
    #21636
    multiple UVs are supported by Verge3D for 3ds Max. What version are you using?
    #21638
    mugga
    Hmm, strange. I’m using version 2.15.0
    Edit:
    I found a workaround. When I’m switching the texture channel from 3 to 2 in the bitmap settings, I’m getting the correct uv (which is number 3) being displayed.
    #34518
    Eugene Zos
    Same here, frustrating. running 3.4
