Home › Forums › General Questions › Take screenshot with HTML elements
- This topic has 10 replies, 3 voices, and was last updated 1 year, 6 months ago by
kdv.
2023-10-07 at 11:55 am #67392
kitt
CustomerHi all,
I’m wondering if it’s possible to take a screenshot of the viewport with all the visible HTML elements overlaying it, either via the take screenshot puzzle or some other means?
Many thanks,
Kitt2023-10-07 at 5:59 pm #67395kdv
ParticipantHardware methods like Print Screen on PC or Power + Volume down in Android.
Or you can try this way
2023-10-08 at 10:50 am #67399kitt
CustomerHardware methods like Print Screen on PC or Power + Volume down in Android.
Thanks, kdv. So, for clarity, I’d like it so that when a user clicks on a button a HTML elements pops-up with the user’s input and then saves a png locally to their computer.
I’ve had a look at your second suggestion already – but I can’t figure out how/where to put the right code so that it happens with the button press – given that my code is split between all the standard Verge source files and my own HTML/CSS. I’ve tried linking the generated .js file to my HTML (which does work) and putting the code in the right section, but it doesn’t seem to handle the event listener correctly and gives me an error in the console. My js knowledge is not sufficient enough to know where I’m going wrong – any advice?
2023-10-08 at 4:59 pm #67400kdv
ParticipantI’ve had a look at your second suggestion already
Which one? Google suggests several variants. Try html2canvas. It works.
2023-10-08 at 5:41 pm #67401mashud008
CustomerI think this puzzle structure for taking screenshots will help you.
You must be logged in to view attached files.2023-10-08 at 6:41 pm #67403kdv
ParticipantI think this puzzle structure
The condition below won’t be met.
2023-10-08 at 7:12 pm #67404kitt
CustomerI’ve had a look at your second suggestion already
Yes, that’s the one I’ve already tried and can’t figure out how to get it right.
This condition won’t be met. You think wrong.
So it’s not possible? I’m confused.
2023-10-08 at 7:15 pm #67405kitt
Thanks, but I have already tried this and it only renders the 3D viewport but none of the HTML elements around it.
2023-10-08 at 7:18 pm #67406kdv
ParticipantSo it’s not possible? I’m confused.
With puzzles? Impossible. With html2canvas? Possible.
2023-10-08 at 7:57 pm #67408kitt
CustomerSo it’s not possible? I’m confused.
Yes, I agree – but I can’t figure out how to make it work and I’m looking for some advice. Are you able to help at all?
2023-10-08 at 8:08 pm #67409kdv
Participantbut I can’t figure out how to make it work
This page contains several working examples. Look through them carefully.
You didn’t even show that error… Should we guess? You didn’t show your code… Should we remind every questioner to provide a little more information than just words?
Working code example embedded in app_name.html
Btw, it won’t take a screenshot of an app embedded in a frame.
