Switching cameras
Home Forums Puzzles Switching cameras
  • #18105
    loom
    Hi
    if i have 2 cameras and switch from camera_A to camera B, change position of camera B and switch back to camera A, the position is not the same as i left camera A. Is there a way to keep the camera as it was? I think it has something to do with the ‘look at’ position. Is there a way to store/recall the ‘look at’ position?
    Cheers,
    Chris
    Here is a sample Scene (select Cube or Cone to switch Cameras)
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:b1c12370a2/applications/CAM_TEST/CAM_TEST.html
    #18123
    This may happen if the user interacts with the view. You can place 2 immobile cameras and move a third one as active instead. Then use the puzzle snap to object together with the look at to restore the original position of your camera.
