Switching between Orthographic and Perspective cameras
Home Forums Programming Switching between Orthographic and Perspective cameras
  • #80676
    David Duperron
    Hi there!
    Is there a way to switch between orthographic camera and perspective camera AND keep (approximately) the same viewpoint (ie keep the same objects in the viewport with approximately the same size)…?
    #80698
    Hi David,
    not sure about automatic way, but you could probably just setup these two cameras manually and switch between them using the set active camera puzzle.
    #80717
    David Duperron
    Hi Yuri!
    Thanks for your answer… I get what you suggest, but the tricky part is to set up the orthographic camera (position, ortho scale and viewport) to “look” the same way as the perspective one (field of view, position, direction), and respectively…
    I need to dig a little bit more…
