Support for 3dsMax Shell material
Home Forums Bug Reports and Feature Requests Support for 3dsMax Shell material
  • #21703
    mugga
    I would like to ask if it would be possible to support the shell material used by 3dsmax.
    I’m mainly using the shell material when baking textures/lighting. It would be great if verge could use the “baked material” slot when exporting.
    #21740
    can you prepare some example of a material which uses shell?
    #21769
    mugga
    Sure, no problem.
    Attached you find a zip with an gltf and the max file. If you need anything else please let me know.
    It would be great if the material in the “baked material” slot, would be applied on export to the glft.
    #21783
    we’ll check it out, thanks
    #24798
    web
    I would also need that functionality. Any updates, when this could get implemented?
    #24807
    We’ll consider implementing Shell material. Thanks!
