Support for 3dsMax Camera Map Per Pixel
Home Forums Bug Reports and Feature Requests Support for 3dsMax Camera Map Per Pixel
  • #33827
    web
    Would it be possible to implement the Camera Map Per Pixel shader/map?
    #33851
    I’m not sure if that map will work for real-time rendering. If the camera rotates how that map will be positioned on the object?
    X | FB | LinkedIn
    #33879
    web
    I dont quite now how this would technically work on the webGL side. But its good when you got prerendered images from highly detailed model and want to project them onto a low poly model.
    It would be great for a current project I’m working on:
    https://dreidesign.com/dev/
    I got a prerendered image sequence rendered a predefined camera path. If you could project this image sequence onto a low poly model it would be great.
