- This topic has 11 replies, 6 voices, and was last updated 4 years, 9 months ago by
Ivan Lyubovnikov.
2019-06-04 at 8:22 am #15320
Anonymous
InactiveI would like to optimize my work for mobile and use “supersampling” puzzle for that, according your puzzle example (in attachment). I guess, it should be founded in post-processing tab, but it is not there. Also “disable rendering” puzzle doesn’t exist in that form as in your screenshot. Please help.
2019-06-04 at 8:30 am #15328zjbcool
CustomerIt is in scene tap. :)
2019-06-04 at 9:18 am #15329Anonymous
InactiveI think, I am blind. I don’t see that puzzles there :(
2019-06-04 at 9:41 am #15332Mikhail Luzyanin
StaffI think, I am blind. I don’t see that puzzles there :(
Now it’s combined with Disable Rendering and called Anti-Alias Last Frame.
2019-06-04 at 9:46 am #15333Anonymous
Inactiveand where ist supersampling puzzle?
2019-06-04 at 10:04 am #15334Mikhail Luzyanin
Staffand where ist supersampling puzzle?
Anit-Alias Last Frame checkbox now instead of Supersamling puzzle. Now it’s automaticly supersample a frame after rendering is stopped if you checked this checkbox.
2019-06-04 at 10:29 am #15338Anonymous
InactiveAha, got it ! Thanks!!
2020-07-04 at 10:53 pm #29660GLiFTeK
Customerand where ist supersampling puzzle?
suggestion: possibly change that in the User Manual, as it still (year later) refers to the supersampling puzzle there, and maybe add info that the anti-aliasing checkbox is referring to the last frame before disabling rendering? lil ambiguous there.
also, do you have to run that in a (time) “every frame” puzzle if you want it constantly checked, if called from within a procedure?
plz share Discord link & on your signature!2020-07-06 at 11:22 am #29720Ivan Lyubovnikov
Staffsuggestion: possibly change that in the User Manual, as it still (year later) refers to the supersampling puzzle there, and maybe add info that the anti-aliasing checkbox is referring to the last frame before disabling rendering? lil ambiguous there.
Thanks, will fix that.
Do you mean the case where you want the anti-alias effect from this puzzles to be applied every frame but without rendering being stopped at all?
2020-07-07 at 10:17 am #29759web
CustomerYeah, I would also like to know. If you can set anti-alias on runtime via javascript/puzzle?
2020-07-08 at 8:09 am #29806web
CustomerI looked a bit further in the api, and found the “enableSSA” method.
So you can change/enable SSA quite easily on runtime:
appInstance.enableSSAA(1);
But not via puzzle, I think.2020-07-09 at 7:58 am #29868Ivan Lyubovnikov
StaffBut not via puzzle, I think.
You’re right, there’s currently no way to enable SSAA only via puzzles.
