Supersampling anti-aliasing and change material
Home Forums Puzzles Supersampling anti-aliasing and change material
  • #48830
    andrasbort
    i’m a new Verge3D user.
    I’m testing this software and i have a issue on apply supersampling.
    I viewd video tutorial for apply supersampling procedure (using “When moved” event and “every frame”)but if i click on my menu for change material object it is not change until i moved camera.
    Any alternative solution?
    Thanks
    #48831
    you should re-enable rendering not only when the camera is moving, but also for the clicking event. You can find the explanation in the same tutorial series – when the UI buttons are clicked, a new texture is loaded. In your case this will be swapping materials instead.
    #48835
    andrasbort
    Thanks a lot!! :good:
