Suggestion: Lighting presets
Home › Forums › Graphics / Blender › Suggestion: Lighting presets
  • #76494
    DJ3D
    Effective lighting and shadows can be a little difficult to set up in Verge3D and Blender, even for users experienced in 3D.
    It would be awesome if Verge provided some scenes with top level lighting and shadow setups. Some examples could be studio/realistic lighting, high contrast/dramatic lighting, basic 3 point lights etc.
    #76495
    Hi there,
    I think lighting and of course shadows can make a break a specific projects that heavily rely on lighting. Using physical lights have a significant performance hit that many projects cant afford and in those situations, baked AO, shadows and lights are more performant but there are situations where physical lighting just has to be used and in those situations I have found that Blenders standard lighting techniques and methods work quite well….with the notable exception being shadows. If I recall the V3D asset store has a free demo called the Tea Ceremony, that might be helpful. Soft8Soft often references the Scooter demo as a preferred way of lighting that may be helpful too.
    I have often thought of a tutorial on shadows but I find there is no general rule that I find common to all projects with respect to dialing in good lighting / shadows. The lighting and shadows are always based on light proximity, and other details unique to a scene.
    However the basic lighting principals that you can find many tutorials on youtube for blender will work in V3D…you will just need to refine the Verge3d Settings for things like blur radius, ESM bias, Shadow Filtering, Map side, cube size, cascade size, high bit depth, soft shadows, light threshold,.etc not to mention light position and intensity. All of these things vary with the version of Blender and Version of V3D you may be using.
    Blender has some plug-ins for 3 point lighting that will generate and allow you to easily modify the settings and it will output properly for V3D.
    If you have a scene you are trying to replicate or an image that shows the look you are trying to achieve, share it / post it and people on here might be able to guide you to a quick solution.
