Home › Forums › Graphics / Blender › struggle with animations
- This topic has 3 replies, 3 voices, and was last updated 7 years, 1 month ago by
Yuri Kovelenov.
2018-01-09 at 2:40 pm #1584
guynat
CustomerHello,
First of all congratulations on this software, I saw your presentation at blender conf and now trying the thing to see if it meets my requirements.
I am currently struggling with animations. I can not figure out the following things :
– why some animations play from start and some don’t : for example in the spinner example, nothing in the puzzle stops the animation when starting… while if I do a simple scene with a spinning cube, the animation will start regardless if I call animation … What am I doing wrong, do I need to animate via armatures ?
– I simply can’t get the “play animation from X to Y” to work and do something when finished…
I must be doing something wrong in Blender in the way I set up my animations but can not figure out what …
Is it about actions in the Dopesheet ? Is it about animating with armatures ? Should I bake or not bake animations
See the attached project :
– I would like none of the animations to start. Right now I have to put an animation stop at the beginning of the script
– On the suzanne animation it loops forever on the first 60 frames and does not execute the part in “when finished” in the puzzleCan you please help ?
Thank you2018-01-09 at 2:59 pm #1586Mikhail Luzyanin
Staff– why some animations play from start and some don’t : for example in the spinner example, nothing in the puzzle stops the animation when starting… while if I do a simple scene with a spinning cube, the animation will start regardless if I call animation … What am I doing wrong, do I need to animate via armatures ?
There’s a checkbox in object’s preferences called Autostart Animation.
– I simply can’t get the “play animation from X to Y” to work, I assume X and Y being frame numbers ? Although I can see it working like a charm in the e-learning demo…
Must work correctly, can you make a screenshot of your puzzlez?
Can you attach a blend file with the example?
Yes, you need to bake your animation using Blender Baker Tool.
2018-01-09 at 3:20 pm #1587guynat
CustomerThank you for the very quick response…
I found the verge3d section in the object panel… and everything was there.So I guess one question left, can you pause an animation ? I noticed stop and start gets it to restart from the beginning
2018-01-10 at 6:16 pm #1589Yuri Kovelenov
StaffHi,
thanks to your feedback we have implemented the missing pause and resume puzzles. If you’d like to you can try them in the developer preview of Verge3D and see if it works for you (replace Puzzles runtime with the attached file).
You must be logged in to view attached files. -
