STOP everything ! Next era is here !
Home Forums General Questions STOP everything ! Next era is here !
  • #72439
    NaxosCG
    You’re next feature to implement is here, stop everything else !
    Like, “nothing else matters !”
    the tool : https://lgltracer.com/viewer/index.html
    3 of my tests from my verge3D’s apps : https://we.tl/t-wjhTJuZ8sO
    Just drag one of them onto the web page
    So, the mission is :
    – contact this guy,
    – work together,
    – have a connection / plugin / solution to get this revolution in Verge3D !
    Only 3 steps, what could be difficult ;-) :heart: ;-)
    For the records, i’ve dragged my Verge3D app folder, and changed some shader settings, then exported GLB file from it.
    • This topic was modified 11 months, 2 weeks ago by NaxosCG.
    #72442
    I implemented this light tracer into one of my commercial projects a year ago. Works quite fine. But not fast enough for the real-time rendering. Just as a final renderer for the scene to take a screenshot. And it works only with standard PBR materials and very hardware-dependent. The author doesn’t know about Verge3D and node-based materials (MeshNodeMaterial) used in it :unsure:
    #72460
    NaxosCG
    I see this as a final high quality renderer :
    The user uses my configurator, make choices, then click a button for nice rendering, et voilà !
    Would this be possible ?
    Can you share a link to the test you’ve made ? So i can see the benefit ?
    Regardless of shaders, i’m used now to swap Physical and USD shaders, for AR on iOS, so i could swap for PBR (physical on 3dsmax?) for this one.
    Regards.
    #72461
    Easy (the lowest button on the right).
    https://cdn.soft8soft.com/…/cbooth/main.html (LGL Renderer version 1.0.10).
    You can use this .sav file to set up the scene faster (click Load in the top right corner).
    #72462
    NaxosCG
    Woooow !!! Your app is amazing !
    Would you share the method to connect to LGL Viewer ?
    Or maybe a tutorial, even a Patreon Tutorial ;-)
    Great configurator btw.
    #72463
    Sorry, but I can’t give a tutorial on how to implement this or that three.js feature into a V3D app. It’s a little complicated task. :unsure:
    But I can add this renderer (1.0.10) into any of your apps for a fair price (but it’s expensive).
    #72464
    NaxosCG
    I get it.
    I’ll wait for a plugin or a collaboration between LGL and Soft8soft ;-)
    #72465
    It’s up to you :unsure:
