Stop “animate param” Puzzle and reverse it?
Home Forums Puzzles Stop “animate param” Puzzle and reverse it?
  • #39856
    Jakob Kolmanic
    Hello,
    I have a questen about the “animate param”-puzzle.
    My target is, that I want to start the parameter animation with a html button and if you press the button again it reverses the parameter animation.
    My solution is, that i have two “animate param”-puzzles.
    One for open and one for close.
    I check the status with a “is open” variable and then I trigger the correct “animate param”.
    It works perfekt until the use presses the button in the time it animates.
    Now my question is:
    Is it is possible to interrupt the puzzle and reverse it from the value it was interrupted? So I would not neet two puzzles.
    I hope I have explained my probleme understandable. :scratch:
    thank you
    #39870
    GLiFTeK
    Try using the updated value
    To to get the current value of the animation, to sense where to stop, and do what’s desired accordingly.
    :good:
