Stop animate param – Bug
Home Forums General Questions Stop animate param – Bug
  • #64528
    Crunch
    Wasn’t an easy bug to isolate as it appears a console log can trigger this error.
    If I disable the console log AFTER the ‘stop animate param’ puzzle, no error and seems to run fine.
    I am using Version: 4.3.0
    #64533
    considering the stop animate is supposed to be inside the animate parameter puzzle.
    and your print console happens after the stop….try placing the print console before the stop.
    • This reply was modified 1 year, 10 months ago by xeon.
    #64564
    That’s just a mistake in the puzzle’s code. This puzzle can be used only as the last element in the queue for now.
    #64569
    Crunch
    Lol.. thanks Xeon, I probably should have added some more context to my post.. Getting the console log to work wasn’t the issue.. Long story short, I had very complex setup that involved iterating input into the parameter fields. I assumed the error I was getting surely had something to do with that and not with the console.log tool I was using to try and diagnose where the error was being tripped.
    Took me all day to figure that out!.
    As KDV pointed out, its probably more of a behavior of the feature (ie killing the whole process) as opposed to any type of technical “bug”…. So I just posted to make note of the behavior so nobody else out there wastes a day like I did trying to figure it out!
    Cheers!
    #64575
    will look into this ASAP :yes:
    #64577
    Hi, the fix will be available in the upcoming Verge3D preview. Thanks for reporting!
    X | FB | LinkedIn
    #64583
    Crunch
    Well no rush guys… easy issue to just avoid.
    My focus has mainly been on making sweet animations instead of stopping them so I haven’t ever done much with the stop param puzzle until yesterday. So much fun!
    I already created a play bar timeline with a playhead that moves along with animation that I can also grab to stop animation, and scrub it forward to advance it. Haven’t figured out getting it animate backwards yet?
    Any pointers there would be appreciated!! Thanks!
    #64587
    Hi!
    I think reversed checkbox in this puzzles does what you need:
    play animation
    set animation speed
    Verge3D Developer
    #64588
    Crunch
    TY Nurgeldi but I am referring to the animate parameter puzzle that doesn’t have such an option.
    #64784
    Fixed in Verge3D 4.4 pre3!
    X | FB | LinkedIn
