Stacking with physics?
Home Forums General Questions Stacking with physics?
  • #23220
    Tom
    Hi is it possible to have a storage container in the centre and items to the right?
    The items to the right can be clicked and dragged to stack within the storage container?
    #23222
    you can possible employ the technique used in this app:
    https://zjbcool.com/app/tower/tower.html
    #23227
    Tom
    Hi Yuri,
    I’m thinking more like how you can move this robot around but with the stacking ability of the tower example.
    Industrial Robot – AR/VR for Engineering
    For example, you can move an object around by the blue control handles similar to the industrial robot but if there is an object in the way it will stack on top.
    Are you able to provide more clues on how the tower example works?
    Thanks,
    Tom
    #23230
    A possible solution can be using drag puzzles to move the object and switch to physics (or just calculate the height manually like in the Tower) when the object is dropped.
    #23233
    Tom
    Thanks, Yuri I will give it a go
    #23257
    :good:
    #33503
    matthew
    Yuri, can I find puzzles for this particular usage? Or maybe you can point me in another direction. Now I need to stack objects on top of each other and I am having difficulties. Any help is much appreciated!
    #33507
    you might try to reach the author through the email stated at the footer of his website https://zjbcool.com/
