Spotlight acting odd
Home Forums General Questions Spotlight acting odd
  • #10357
    johngrigni
    I’m trying to update an older model to the new 2.9.2 version, and I’m having a problem with spotlights acting strangely, like there is a diagonal cut across them, but not always. I’m not sure what the problem is. I’m attaching a screen shot.
    Nothing weird about the wall on the right, no strange normals, just a flat plane.
    Any ideas what is happening?
    #10387
    johngrigni
    I thought I should clarify, the spotlights are pointing straight down.
    #10399
    Sorry for the delayed response. Can you please share some example that manifests this issue? Thanks!
    #10421
    johngrigni
    Here it is.
    #10423
    johngrigni
    If it matters, the behavior is the same in Safari and Chrome on my iMac.
    #10431
    Thanks for sharing the example. This issue is a limitation of real-time rendering. If you check your scene within Eevee you’ll notice the same behavior. In Cycles, the lit surfaces produce additional lighting to each other smoothing out the seams. I created a simple test case – a point lamp inside a cube that you can check with Cycles, Eevee and Verge3D to see the difference.
    A good workaround to this would be to bake the lights for the room.
