Home › Forums › Graphics / Blender › Some vertice won't take weight
- This topic has 28 replies, 3 voices, and was last updated 5 years, 10 months ago by
Mikhail Luzyanin.
2018-03-01 at 11:37 am #2593
Philip Fong
Customer2018-03-01 at 12:46 pm #2595Mikhail Luzyanin
StaffBy the way, your loader image not clean
What browser and device do you use?
2018-03-01 at 4:30 pm #2597Philip Fong
CustomerFirefox, Xiaomi phone.
2018-03-02 at 7:32 am #2605Mikhail Luzyanin
StaffNothing change to the dino, just the weight paint clean up and environment texture.
When shadow is enabled, the blurry effect look less obvious.
Ok, we try to reproduce the issue on different PC. Can you also test your model on different PC and look is the problem appears everywhere or not and write wich hardware do you used for tests? Because we still can’t find the difference on our PCs.
Thank you will look at it closely.
2018-03-06 at 4:52 pm #2676Philip Fong
CustomerThink the blurry effect is mip map in Verge3D, zoom in and out will see the difference, I hope by scaling the whole scene can control the distance.
2018-03-07 at 1:20 pm #2691Mikhail Luzyanin
StaffThink the blurry effect is mip map in Verge3D, zoom in and out will see the difference, I hope by scaling the whole scene can control the distance.
I found why you see the difference. You used the diffuse texture also as bum map, as I can see in your screenshots and blender file where you set up a bump as 0.187. It give add some details to the texture so it looks like it less stretchy, but in the engine bump is not supported and it omited. Try to bake normal. Because we testet your model on multiple PC and can’t find the difference. We see the difference only if we switch on the bump on the model and try to export.
2018-03-07 at 3:00 pm #2698Philip Fong
CustomerThe latest scene is a baked texture, only my first test has bump map.Trex-web
2018-03-07 at 4:08 pm #2703Mikhail Luzyanin
StaffThe latest scene is a baked texture, only my first test has bump map.Trex-web
Ok, thank you for the new example, as I said before the texture in the old and new examples little different and now we can see the difference in blender and the engine. It’s because of anisotropic filtering, we’ll added it to our TODO list and it will be available to enable it in one of the next releases.
2019-06-10 at 7:11 am #15502tomcd
ParticipantDear Developers,
I made some animation with 4 bones (m, m.001, m.002, m.003) controlling the mouth movement with weight paint. I clean up all other bones weight paint that may affect the mouth. The result looks fine inside Blender & Cycle, but when view in “sneak peek” at the end the mouth movement gone wrong.
Could you please help? Thank you!I attached the Blender file
You must be logged in to view attached files.2019-06-10 at 7:18 am #15505Mikhail Luzyanin
StaffI made some animation with 4 bones (m, m.001, m.002, m.003) controlling the mouth movement with weight paint. I clean up all other bones weight paint that may affect the mouth. The result looks fine inside Blender & Cycle, but when view in “sneak peek” at the end the mouth movement gone wrong.
Could you please help? Thank you!Hi, you need to clean all weight with 0. I done it for you on the character’s head and it’s started to work propertly. (see atachhed file)
2019-06-10 at 7:37 am #15508tomcd
ParticipantThanks! But I cannot open the file. I am using Blender 2.79b (company pc cannot run 2.8). Do I need to Select the head> edit mode> select all vertex> object data tab>Vertex Groups> set weight bar from 1.000 to 0 ?
2019-06-10 at 7:54 am #15509Mikhail Luzyanin
StaffThanks! But I cannot open the file. I am using Blender 2.79b (company pc cannot run 2.8). Do I need to Select the head> edit mode> select all vertex> object data tab>Vertex Groups> set weight bar from 1.000 to 0 ?
You just need to go to vertex weight paint mode and on the left pannel select Clean then All Vertex Groups and set limit to 0.001
2019-06-10 at 8:03 am #15510tomcd
ParticipantIt’s working fine now! Thank you very much !
2019-06-10 at 8:05 am #15511Mikhail Luzyanin
StaffCo-founder and lead graphics specialist at Soft8Soft.
