Home › Forums › Graphics / Blender › Some vertice won't take weight
- This topic has 28 replies, 3 voices, and was last updated 5 years, 10 months ago by
Mikhail Luzyanin.
2018-02-23 at 10:30 pm #2364
Philip Fong
CustomerThe dinosaur neck weight paint issue, I have tried delete and replace the affected area with new bone but that part just won’t accept the weight paint, it worked fine in Blender. Any idea what is wrong?
2018-02-24 at 6:29 pm #2373Philip Fong
CustomerNever mind, I have never encounter Blender automatic weight can produce such artifact, no choice but to delete the weight group and start fresh.
2018-02-25 at 9:28 am #2375Philip Fong
CustomerCorrection, each vertice only allow two bones. What a nuisance.
2018-02-25 at 7:45 pm #2380Mikhail Luzyanin
StaffCorrection, each vertice only allow two bones. What a nuisance.
Sorry for late response, we’ll look at it closely. Can you attache the file with more than two bone weight on the vertex version?
2018-02-26 at 7:54 am #2384Mikhail Luzyanin
It should not be so, we are support up to 4 bones weights per vertex, maybe there is some bug, can you attach the example?
2018-02-26 at 8:17 am #2387Philip Fong
CustomerCompare blender animation between the jaw -neck – chest area, the initial mesh binding have been deleted and rebind, deleted bone, add new and repaint. SubD modifier won’t work.
2018-02-26 at 8:40 am #2390Mikhail Luzyanin
StaffCompare blender animation between the jaw -neck – chest area, the initial mesh binding have been deleted and rebind, deleted bone, add new and repaint. SubD modifier won’t work.
Dino-x
Yes, we found the problem. Your model has more a lot of weigths on each vertex, but Verge3D (also as Blend4Web) supports only 4 weights per vertex. You need to do a clean on your model for All Groups with limit 0 to remove unused vertex weights.
Because the engine takes only first four weights on vertex and discard the other and if your vertex groups with weights stand as fifth or more they also be discarded. It’s better to do a clean as I said before and don’t use more than four weights per vertex.
2018-02-26 at 4:17 pm #2489Philip Fong
CustomerThank you very much Mikhail.
2018-02-28 at 4:52 pm #2570Philip Fong
CustomerWhy are texture appear stretchy in Verge?
2018-03-01 at 8:08 am #2582Mikhail Luzyanin
StaffWhy are texture appear stretchy in Verge?
Can you point us where? I can’t see the difference.
2018-03-01 at 9:03 am #2586Philip Fong
CustomerIt appear blur at zoom out to a distance, close up view pixel is crisp. Is there a way to control the sampling?
2018-03-01 at 9:21 am #2588Mikhail Luzyanin
StaffMaybe you have specific blender preferences setup, because I have the same blurring in blender and the engine. Can you make a screenshot of your preferences in system settings panel?
2018-03-01 at 10:43 am #2590Philip Fong
CustomerThe difference is published gltf in the browser, not Blender interface. Like anti alias or anisotropic filtered.
2018-03-01 at 10:56 am #2591Mikhail Luzyanin
StaffI’ve ask that because we can’t reproduce the issue, we have the same result in Blender and the engine. May be you added additional maps to dino that we don’t have in our file? Can you attach the last version of dino?
2018-03-01 at 11:33 am #2592Philip Fong
Customer -
