- This topic has 29 replies, 5 voices, and was last updated 6 years ago by
pierre 3d.
2019-03-26 at 12:58 pm #13268
pierre 3d
Participantblender 2.8 +verge3d+visualstudiocode
the only problem i get was i was obliged to edit the gltf file with visualstudiocode to change lightpoint parameter which doesn’t the same as in blender2019-03-26 at 1:15 pm #13272elk
CustomerCool. The scale is not correct ofcourse, but is the amount of rotation of the planet relative to eachother correct ? Might be cool to have some options to adjust the “speedup”. Good job
2019-03-26 at 1:50 pm #13273pierre 3d
Participantthanks yes it is not finished
i want to put the exact position of planet with the datebut i just see that it doesn’t work in chrome
( works in firefox and edge)
2019-03-26 at 2:16 pm #13276elk
CustomerCool. Yeah, it holds on 100% here in chrome …
2019-03-26 at 2:44 pm #13281Yuri Kovelenov
Staff2019-03-26 at 3:16 pm #13286pierre 3d
Participantdo you want the blend file too in the zip?
That is a very informative project!
Indeed, for some reason it does not work in Chrome. Is it possible that you attach here a zipped project for us to investigate it further?
2019-03-26 at 3:25 pm #13288Yuri Kovelenov
Staff2019-03-27 at 7:19 am #13300pierre 3d
Participantok i have solve the problem with chrome :)
it was du to the baking of a follow curve but now it s work fine in chrome too
the only problem in chrome is the panning of the camera which is superfast i don’t know if i can reduce it in chrome or in verge3d?ok solve too it s logitech smooth scrolling2019-03-27 at 8:05 am #13303Yuri Kovelenov
Staff2019-03-27 at 8:23 pm #13339pierre 3d
Participantyes
i think it s because i keep the constraint copy rotation after the baking
https://ahp.li/f1c15a86b286416cc85a.blend2019-03-28 at 7:01 am #13345Yuri Kovelenov
StaffThanks for the file! I’m reproducing the issue. Looks that you’re using a very long animation which requires a lot of processing in JavaScript. So Chrome thinks that it is running through an infinite loop. We’ll try to optimize the processing of animation and/or issue some recommendations.
2019-04-15 at 3:36 pm #13927pierre 3d
Participantwell it seems it don t work with verge3d server
http://blend4web.pagesperso-orange.fr/systeme_solaire/systeme_solaire.html2019-04-16 at 7:38 am #13942Yuri Kovelenov
StaffHi,
the project is now looking even nicer! Congratulations with the great work.
May be I’m missing something, but both links work for me equally well.
You must be logged in to view attached files.2019-04-17 at 6:02 am #13984pierre 3d
Participanton verge3d network i get
Error: TypeError: NetworkError when attempting to fetch resource.
when i check the position of the planet on the serverjust another probleme for the bilboard name of the planetes i use a constraint trackto camera but it doesn’t seem to work
and in firefox the background image doesn’t appears
2019-04-17 at 8:54 am #13996Yuri Kovelenov
Staffon verge3d network i get Error: TypeError: NetworkError when attempting to fetch resource
I see you are retrieving data from a remote location
http://vo.imcce.fr/webservices/miriade/ephemcc_query.php
via non-secure protocol, which conflicts with HTTPS-enabled Verge3D Network.BTW I noticed a rather big scene is loaded in your app (bin file 45 megs). You might want to enable asset compression to make it load faster
https://www.soft8soft.com/docs/manual/en/introduction/Asset-compression.html -
