Soft8Soft Extension causing Renderset Addon to crash
Home Forums Graphics / Blender Soft8Soft Extension causing Renderset Addon to crash
  • #81148
    Philipp
    Hy,
    the Soft8Soft Repository installation (4.8) way causes crashes with another addon (Renderset from Polygoniq) in blender 4.4.
    I even can’t delete the Soft8Soft repository entry from the extension repository list. every time i delete it it will come again after startup. i have uninstalled the verge3d addon from blender. but i need both addons, so please connect with the polygoniq team to resolve that.
    Here is my conversation with polygoniq team:
    Hey, im unable to rename contexts in the addon panel. Blender 4.4.0 renderset 2.0.1
    doubleclick on contex name as usual and type name, as soon as i hit enter it reverts back to the old name.
    thx for any help!
    phil
    solved by disable soft8soft (verge3d) repository and uninstalled and reinstalled renderset
    sadly the repository activates itself every time after render (F12) again.
    remove the repository also reenables after start.
    why ist a other repository influencing renderset?
    i have to uninstall and reinstall renderset everytime after a render
    RenDip —
    I think if you remove Verge3D for Blender addon completely, renderset will function properly.
    Both addons are relating to render and may have some conflicts when working together. Renderset respects Blender native render pipeline while the other render addons may override it. Turbo Tools, for example, we have to call its specific render operator than Blender native one for both addons to work properly. I guess Verge3D might be in a similar situation. I understand it may not be a feasible option for you to remove Verge3D, but I don’t have a better option either, unfortunately.
    thx
    phil
    • This topic was modified 2 days, 7 hours ago by Philipp.
    #81151
    That’s strange because we do nothing with Blender rendering at all.
    Regarding Soft8Soft repo, you can try to remove the file:
    AppData\Roaming\Blender Foundation\Blender\VER\scripts\startup\verge3d.py
    inside your user folder to disable automatic activation of Soft8Soft repository.
    X | FB | LinkedIn
    #81153
    BTW, is there are any errors printed in Blender console window?
    X | FB | LinkedIn
