Sneak peak fails to load for this Blender file
Home Forums Graphics / Blender Sneak peak fails to load for this Blender file
  • #66384
    c4cc
    Sneak Peak only loads halfway for my object. How to get this to load normally?
    #66385
    Press F12 and see the console log.
    #66386
    c4cc
    Now read the error, find the reason and eliminate it.
    #66395
    c4cc
    TypeError: T is undefined.
    Do I use Blender or programming to solve this problem? I don’t know if I should debug via programming or simply changing my Blend file
    #66396
    The problem is in your .blend file only. It contains several “Armature” modifiers with wrong target objects (they are the problem). Also it contains a lot of useless “Armature” modifiers with no target objects and armatures without bones (they are not the problem, they are just useless).
