Snap to grid
Home Forums Puzzles Snap to grid
  • #7610
    Atomfreak
    Need some advice on how I could move an object in XY but with the snap to grid effect. :unsure:
    I am also trying to reproduce the same effect for a rotation of the Z axis at every 90 degree. I’m also looking for how I can apply an XY snap distance.
    Basically, the same effect as the snap to grid tool in 3DS max on the grid.
    I tried several combinations with set positions but without success.
    #7626
    Here is how you can implement snapped dragging with Puzzles:
    #7628
    Attaching the logic save file here too:
    #7642
    Atomfreak
    Thank you very much Yuri. It helped me a lot.
    Also a big thanks for taking the time to include the .xml! :yahoo:
    #7646
    Sure, glad it worked for you. :good:
    #67265
    NaxosCG
    This, Yuri, was very usefull, thanks !!
    What if i need to change the “grid” space : make it 2 x 2 instead of 1 x 1 ?
    “round” option will always become integer, so “1×1” grid
    Thanks for help.
    #67266
    NaxosCG
    Forget it, i’ve managed it, using the same puzzle parts used for rotation, but with “2” instead of “90”
