- This topic has 15 replies, 8 voices, and was last updated 5 years, 3 months ago by
Yuri Kovelenov.
2018-02-05 at 12:03 pm #1919
enzyme69
ParticipantI have only used Verge 3D for few hours and already hooked! I like the simplicity and really want to find out more.
I am thinking to make some kind of “interactive app” that basically react to my input from iPhone X via OSC or something.
For now, I need to find out a simple interaction like to be able to create setup like this:
Slider with attribute 0 – 1 to control Shape Key blends of Object just like morphing shape keys inside Blender.What would be the easiest to perform this interaction?
So far, I can do click that trigger animation of shape keys. But wonder if actual “driver” and “driven” can be easily setup in Verge 3D.
So eventually I would like to be able to have Slider to control “Action” animation. Or to have bunch of values (interactive) to control bunch of shapes.
This Verge 3D is promising.
2018-02-05 at 1:23 pm #1929
Yuri KovelenovStaffThanks for your interest and kind words. Alas for now this can only be done with programming. We’ll think on implementing some puzzles for that.
2019-02-19 at 6:56 pm #11558
roybellCustomerSlider to control “Action” animation.
Would be great!
2019-02-20 at 8:49 am #11580
Yuri KovelenovStaff2019-03-02 at 2:55 pm #12064
dssctrCustomerWow sounds great. Might there be any examples in the future?
2019-03-03 at 10:35 am #12073
Yuri KovelenovStaffYeah, we’ll think about making an example/demo for sliders.
In the meantime, you can check out this tutorial https://www.w3schools.com/howto/howto_js_rangeslider.asp
You can use the HTML puzzle get attrubute to retrieve its value.2019-03-03 at 1:17 pm #12075
AndrejusParticipant
2019-03-04 at 5:02 pm #12114
dssctrCustomerThanks! :)
2019-03-04 at 5:19 pm #12115
roybellCustomerYeah, we’ll think about making an example/demo for sliders….
Thanks Yuri!
2019-03-20 at 2:11 pm #13050
NaxosCGCustomerHi Enzyme69,
Something tells me that you were a WireFusion user, back in early 2000’s, were you ?Wirefusion was a great tool : mixing 2D and 3D as simple as a Wysywyg tool, nodal “output-input” coding system… i miss it a lot !
Verge3D is quite close to that, but too often we need to put hands in the code, and i can’t do that.
So a slider puzzle would be great !
2019-03-20 at 2:21 pm #13052
Yuri KovelenovStaffI started doing an example with Google web designer. GWD offers a ready-to-use slider component. You can retrieve its value with puzzles, and then display it as in my example or use in a 3D scene.
2019-03-20 at 2:32 pm #13055
roybellCustomerI did a test .. but there is some error. For example, when you hover the mouse over the sliders without doing anything, the model changes:
2019-03-20 at 2:38 pm #13057
Yuri KovelenovStaff2019-07-08 at 2:04 am #16274Ozbend
CustomerHow to affect the movement of an object using the slider? Now when you drag the slider, the animation plays completely, no matter how much the slider moves.
2020-08-22 at 9:03 pm #31862farzinkhodadadi
Participantany one can give me sample of made puzzle how to connect the slider to change scale?
