sky dome light background not working
Home Forums Graphics / Maya sky dome light background not working
  • #50456
    moiamy
    Hello
    I would like to use the sky dome light as global source of illumination (without texture) with a black background
    I have followed the tutorial (use Camera background color + Verge 3D / rendering background on)
    But I still got a white background
    What did I miss ?
    Also I put AiSkySomeLight / Visibility / Camera to 0
    #50482
    You need to use this setup for skydome instead of simple backgound color on a camera. Background color on a camera will work only if there’s no skydome sphere. BlendColors node not necessery, just remove it. In camera input you can connect any you want like simple color or any other environment texture.
    #50501
    moiamy
    Thanks Mikhail. It works great.
    I have to figure now about transparency & double side
    Is it cover in your tutorial ?
    [update]
    I have just found informations for transparency & double side :)
    #50508
    :good:
