Show Framerate of App
Home Forums General Questions Show Framerate of App
  • #41388
    jdhutchinson
    Is there a way in puzzles to show the framerate when running an app in a div, for debugging purposes?
    #41395
    GLiFTeK
    Look at the top of your preview frame in your puzzle editor.
    Frame rate is there.
    Also…
    Starting from version 3.2, Verge3D comes with the built-in FPS counter. You can activate it by:
    Quickly pressing F, F, F (triple F) on your keyboard.
    Using JavaScript and the showFPS() API method.
    From – user manual check your frame rate
    #41424
    jdhutchinson
    Thanks GlifTek! The preview fps is great, I’m not sure if it’s my html elements in index.html that are slowing it down. Could this be feasible?
    So far I’ve used print performance info puzzle, but this is only a snapshot. Looks like I need to do more digging into what might be resource hogging, or if it’s just a bad internet connection.
    Thank you for your discord welcome! :good: :rose:
    Also a quick :good: for the V3D documentation – I need to spend more time with it, but it’s very good I think!
