shopwFPS Method, Styling
Home Forums Programming shopwFPS Method, Styling
  • #43901
    jdhutchinson
    Hi, How can I style the showFPS method? It has no class or id if i add it to the document through an exec script puzzle?
    #43910
    This method uses the stats.js library. You can modify the code of this library, then create your own Stats() class and place its instance under app.stats.
    X | FB | LinkedIn
    #43932
    jdhutchinson
    Dear Alexander,
    Thanks for explaining this. I copied the stats.js file and amended the below line as needed.
    container.style.cssText
    would you be able to explain this? Would this be best done in an exec script puzzle to overwrite, or visuallogic.js, or “awesomeproject”.js? Same with instancing the class – which file does this need to be done in, and also a script tag I guess?
    Or, in the prepareExternalInterface area of “awesomeapp”.html? :scratch:
    I tried following:
    threejs cookbook to no avail. The js file structure is different in their simpler example, so I’m not sure how to approach.
    Does showFPS not have any callable methods?
