Sharing application on Sharepoint
Home Forums Graphics / Blender Sharing application on Sharepoint
  • #43659
    michelkohler1
    Hi there,
    Does anyone knows if it´s possible to share application on sharepoint, using the onedrive or the sharepoint as the web server. O tried using iframe, but didn´t work.
    I think this is important as you have many companies as customers, and they might like to keep some project internally not on the web.
    Also, would like to know how private is to use Verge3d network to publish.
    So far i´m really, really enjoying using verge3d locally. I see so many application we can use on the company I work. Also given a try out to go, is great strategy for marketing Verge3D. I will show what I have done internally and ask to buy a license.
    #43933
    Avier3D
    Hello,
    You are probably for problems in it, since Sharepoint changes its internal structure almost weekly. Even if it has web cappabilities, it’s a bit of a frankenstein.
    SharePoint is ok for office use but it’s not a developer/author pipeline at all.
    If you want to share projects, or use something like GitHub, or setup a network shared drive that can be mirrored remotely, so every user has all the same application paths.
