Share to LinkedIn a long URL link
Home Forums Programming Share to LinkedIn a long URL link
  • This topic has 3 replies, 2 voices, and was last updated 1 year ago by kdv.
  • #69167
    Mariusz
    Hi! I have “share” buttons in my application but I have a problem with sharing the link to LinkedIn. First of all, I use the CyberFox Link Parser plugin so the customization is saved in the URL with parameters. This makes the URL quite long. I share it on LinkedIn with the puzzles that you can see below.
    And now the problem is that LinkedIn shortens the shared links… That means that the URL loses the customization parameters which is problematic. Do you have any workaround that could be used in this situation? I don’t know, something like using Bit.ly?
    Here you can read more about why LinkedIn is shortening the links: https://sociality.io/blog/how-to-post-on-linkedin/#7-how-to-avoid-link-shortening-on-linkedin
    #69180
    In your case it doesn’t exist :unsure:
    #69191
    Mariusz
    What a shame, but thanks for the answer anyway! I hope LinkedIn will fix this issue on their side one day…. ;-)
    #69192
    They do not consider it as an issue :unsure: That’s just a max 25 character limit. You can find another way to save the scenes’s parameters to get a shorter result link.
