Shape Key set above 0 (at 0.5) causes unwanted black color on faces?
Home Forums Bug Reports and Feature Requests Shape Key set above 0 (at 0.5) causes unwanted black color on faces?
  • #79817
    c4cc
    Shape key set at 0.5:
    ol4x1
    Puzzles and Blend file:
    https://drive.google.com/file/d/1yO4sZ6mjgWa25o0SUMtOfXib9DEO4T4Q/view
    Those faces in verge3d is black when shape keys set at 0.5, yet when it increases, it switches to its intended color. Why?
    HealthBar Frame’s shape key at 0.5:
    ol4x1
    After increasing shape key:
    ol4x1
    How do I prevent the unwanted black color? Want these faces to be its intended color
    #79875
    c4cc
    Even if I change shapekey to 0 in Blender, and reupload blend file as gltf, the object at shapekey 0 is at desired color – just that when it becomes 0.5, it becomes messed up black
    #79931
    do both shape key objects share the same color?
    #79936
    c4cc
    If you mean both the green and grey bars, no, they do not share same color.
    #79954
    a little more accurate modelling (without overlapping in geometry) can do the trick…
    #79962
    c4cc
    kdv, thanks for your answer, it gave me an idea to simply adjust the relevant vertices’ location for shape key value 0, after issuing new shape key value. It works. I learnt a lot from your answer as a byproduct.
    Btw, do you know how to activate individual clones in a list, only when certain conditions are met? Problem is, when one clone in list is activated, other clones do not trigger even though conditions are met for other clones as well
    l41
    • This reply was modified 2 months, 3 weeks ago by c4cc.
    #79977
    that’s because your are using one global variable for all clones. After the first clone changes this variable the condition won’t be met for all other clones.
