Home › Forums › Graphics / Blender › Shadows in Blender
- This topic has 18 replies, 3 voices, and was last updated 6 years, 7 months ago by
tcdoe.
2018-07-10 at 2:27 pm #5592
AndreasResch
ParticipantHello.
I can’t get my shadows to work with Verge3D. I tried all the checkboxes I can find but had no luck. Maybe somebody can gibe me a hint.
Attached is a simple scene with a simple sphere and point light.
Cheers,
AndreasAttachments:
You must be logged in to view attached files.2018-07-10 at 2:45 pm #5594Mikhail Luzyanin
StaffHello.
Hi, unfortunally point light doen’t support shadows. Use sun or spot for shadows and other for additional lighting.
2018-07-10 at 2:57 pm #5601AndreasResch
ParticipantI see. I replaced the point light with a spot light. If the spot light is close to the sphere, it casts a shadow but if I move the light away from the sphere, the shadow disappears. I’ve attached the updated scene.
Is there a way to get soft shadows in Verge3D?
Cheers,
AndreasAttachments:
You must be logged in to view attached files.2018-07-10 at 3:02 pm #5603Mikhail Luzyanin
StaffI see. I replaced the point light with a spot light. If the spot light is close to the sphere, it casts a shadow but if I move the light away from the sphere, the shadow disappears. I’ve attached the updated scene.
Shadows parameters has hear and far clipping, just increase the far clipping.
Soft PCF shadows it’s already a soft shadows. You mean soft like in cycles?
2018-07-10 at 3:10 pm #5604AndreasResch
ParticipantI set the far distance pretty high already (100000000). Didn’t work either. Check out the attached scene.
With “soft shadow” I mean a shadow like an area light would create.
Cheers,
AndreasAttachments:
You must be logged in to view attached files.2018-07-10 at 3:27 pm #5608Mikhail Luzyanin
StaffI set the far distance pretty high already (100000000). Didn’t work either. Check out the attached scene.
Set near shadows something like 0.001 it will fix this.
Unfortunally for now there’s no way to get soft shadows, only bake them.
2018-07-10 at 3:30 pm #5610AndreasResch
ParticipantHello.
Changing the near value doesn’t help either – I already tried that before. And baking is fine, when you have a few objects in the scene. But if there are hundreds of them, it takes way too much time and resources.
Cheers,
Andreas2018-07-10 at 4:00 pm #5613Mikhail Luzyanin
StaffChanging the near value doesn’t help either – I already tried that before
Try to set it to 0.1 and far to 100. I corrected your file a little bit. Just reset to default value and lower the bias.
Unfortunally for now is now way to setup a soft shadows.
2018-07-10 at 4:06 pm #5615AndreasResch
ParticipantToo bad.
One final question. Why is the scene brighter, when I click “Sneak Peak” with Verge3D set as render engine compared to when I have Cycles set as render engine?
Cheers,
Andreas2018-07-10 at 4:11 pm #5616Mikhail Luzyanin
StaffToo bad.
When you exporting from Verge3D engine it takes an Blender Internal preferences for export, when you export from cycles it uses Emission node for light setup. Now we in migrate stage for full support cycles that’s why there’s some different dehavior.
2018-07-10 at 4:17 pm #5617AndreasResch
ParticipantI see. Well – I thought I might be able to get a better results than with Blend4Web while not having to spend too much time for the conversion of my Cycles scenes. At the moment the transition still seems to be a bit bumpy. I especially was hoping for an easy implementation of refractions, but I just tried the Principled BSDF and the Glass shader and both don’t seem to be implemented yet.
I will follow the progress of the program and give it a try again, when Cycles is supported a little better.
Thanks for now,
Andreas2018-07-10 at 4:30 pm #5618Mikhail Luzyanin
StaffI especially was hoping for an easy implementation of refractions, but I just tried the Principled BSDF and the Glass shader and both don’t seem to be implemented yet.
Yes, refraction is still not supported, we only started to support cycles nodes and it was our first release with some of cycles nodes support.
I think the near full support will be finished at the end of this year or may be earlier.
2018-09-14 at 2:13 am #7222tcdoe
CustomerThis is helpful. I too need even basic soft shadows and related cycles settings to ‘work’. Right now my materials look great in Blender but basically terrible in the verge sneak peek (or published). I’m still learning; I think it would be very good for you to update your video tutorials with a more comprehensive materials and lighting example using Blender cycles. I haven’t found anything in your current video tutorials… maybe I missed it? thanks.
CEO, ABĒMIS LLC
visit: abemis.com2018-09-14 at 8:18 am #7236Mikhail Luzyanin
StaffI too need even basic soft shadows and related cycles settings to ‘work’.
There’s no soft shadows in the engine yet.
The support of cycles materials is still on the way, some of the nodes are not supported some of them still works different (for example roughness looks different), hope this will fixed soon too.
I’ve already made a series of tutorials on youtube about creating of Industrial Robot (that was completely made using only cycles nodes) but it’s in Russian and still wait to translate it to English. Because we are Russian our process of creating tutorials for English speaking users little bit longer than in other software.
2018-09-15 at 1:07 am #7287tcdoe
CustomerOk Thanks for info!
I have some russian speaking Bioengineering colleagues; I think they would be happy to help translate. I think I know which videos you mention, but just to be sure, which youtube vids are we talking about? Thanks.CEO, ABĒMIS LLC
visit: abemis.com -
