Shadow offset
Home Forums Graphics / Blender Shadow offset
  • #27115
    sergegusev
    Good day.
    Is there way to get rid of a strange shadow effect – I see the shadow offset under a table’s desk.
    Shadow offset
    Thank you in advance,
    Serge
    #27134
    GLiFTeK
    thinking it’s a desk with another off camera plank to the right identical to the one with the shadow issue?
    if so looks like that’s what’s causing the shadow.. and im thinking you have ‘cast shadow’ in object data panel turned off for the top plank maybe?
    eevee doesn’t have an option like this as far as i know and i don’t use cycles ever but if you’re using cycles you can make sure the object’s ray visibility section’s shadow is checked for the top plank.
    5
    if in eevvee i’d play with the shadow’s section of your render data panel
    #27137
    sergegusev
    Thank you, it helped.Changing Shadow -> Cube Size to 4096 has solved the problem.
