Home › Forums › Bug Reports and Feature Requests › Shadow Mode Transparency
- This topic has 17 replies, 4 voices, and was last updated 1 year, 10 months ago by
xeon.
2023-05-15 at 7:05 pm #63779
CustomerHi there,
Hoping we can bubble this up to the top of new features to add.
Currently, the shadow mode for transparent objects is either opaque or none.
We are constantly fading in and out objects with and without transparency and it would be so much nicer if the shadow would fade out as well. Currently, if you use a mix shader and a transparent shader with a value for the factor you can fade in and or out your object. Unfortunately, the shadow just pops off rather than transitions via a nice fade. This sort of fade works in EEVEE…just need the same effect in Verge3d.Even if there was a clever work around, I would be happy to try that but need something…please.
Tutorials - https://www.xeons3dlab.com2023-05-17 at 4:24 am #63816visualizer
CustomerYes
Thats really a nice thing & even I faced this issue at couple of trials.2023-05-17 at 4:29 pm #63835kdv
ParticipantYou can do this trick with the help of ShadowMaterial
https://v3d.net/jnv
Won’t work with Sun + ESM shadows. Works with PCF and VSM shadows.And it’s hardly possible to apply it to the whole shadow map. At least till now three.js still can’t provide such a feature…
2023-05-19 at 6:04 am #63869xeon
Customerany chance you can link a zip of the project file? I would like to take a look.
Tutorials - https://www.xeons3dlab.com2023-05-19 at 7:42 am #63873kdv
ParticipantSure
https://drive.google.com/file/d/15XYbbvSKus4mnoijHJQEwAbRtMqtNOK7/view?usp=sharingPuzzles and JS coding. Fast and expensive.
2023-05-20 at 6:04 am #63892xeon
Customerthank you for sharing. Neat little trick. Great for simple shapes but oh my gets exponentially complicated with multipart objects and shadows in on contoured surfaces. The additional shadow catcher geo is not optimal but it can work in some cases. Great to know.
Tutorials - https://www.xeons3dlab.com2023-05-20 at 6:10 am #63893kdv
ParticipantYeap, it’s not universal and quite hard to apply to complex shapes. But in some cases it will do. Better than nothing.
2023-05-28 at 7:48 pm #64139kdv
ParticipantAn interesting fact about shadows in version 4.3.0+
4.2.0 vs 4.3.1
Looks like shadows are casted by the opaque part of the object only. Works with Alpha Clip blending.
alphaTest
value affects the shadow.Looks not bad in practice. Much better than rectangular shadows for leaves.
2023-05-28 at 10:43 pm #64145xeon
CustomerI am using 4.3.1 and shadows are just not as good as they once were for sure but as long as you have an opaque object casting a shadow it all works. Things start getting sketchy when you have objects that have transparency for sure.
Tutorials - https://www.xeons3dlab.com2023-05-28 at 10:52 pm #64146kdv
ParticipantYou didn’t get the point…
2023-05-29 at 4:49 am #64155xeon
CustomerPerhaps I don’t understand what you are saying.
In looking at your image….I don’t know if the thing that looks like a tree branch is a 2D image or a 3d object. Is it a 2D image on a plane with an alpha?
If its a 2D image then shadow on the right is typically what we would see in V3D regardless of the blend mode and regardless of the shadow mode.
And what I think you are saying is if we adjust the alphatest value we can set that value to reduce the shadow to be transparent for the currently opaque parts of the image.
I may have this all wrong but if you could explain I would greatly appreciate it.
Tutorials - https://www.xeons3dlab.com2023-05-29 at 11:18 am #64157kdv
ParticipantThat’s just a plane with a texture on it. The same plane in both cases. Alpha Clip on the left, Alpha Blend on the right.
2023-05-29 at 3:45 pm #64171Mikhail Luzyanin
StaffShadows in Verge3D respect only mesh, it was from the first day of Verge3D till now.
2023-05-29 at 4:16 pm #64172kdv
Participantjust compare the trees’ shadows here
https://v3d.net/ec5
and here
https://cdn.soft8soft.com/demo/blender/firstperson_camera/firstperson_camera.html
Geometry is the same. Find the difference.Puzzles and JS coding. Fast and expensive.
2023-05-29 at 6:08 pm #64173kdv
ParticipantShadows in Verge3D respect only mesh
not exactly (starting with three.js r147 and v3d 4.3.0)
Blender => Verge3D
