Home › Forums › General Questions › shading error
- This topic has 14 replies, 2 voices, and was last updated 6 years ago by
Mikhail Luzyanin.
2019-03-24 at 3:02 pm #13185
NaxosCG
CustomerHello,
After some tests that went well, i’m starting a new one, with a large-polycount test, and the render of shaders is quite strange, as if all my shaders were wrong with high metalness / IOR.Here see the object in 3DSmax (i’ve imported it in the default cube scene, and the exported glTF.
I’ve checked twice my shaders : made from scratch physical ones, with classical values and the environment is the one from Cube.max default scene (see second picture)
any idea ?"1+1=3... for large values of 1"
2019-03-24 at 3:04 pm #13189NaxosCG
CustomerThe whole mesh scene is 15 272 237 polys, that is a lot i know : is there anyway that this large number of polys could prevent the shading to work normally ?
2019-03-25 at 7:07 am #13213Mikhail Luzyanin
StaffCan you share a max file with textures?
2019-03-25 at 1:25 pm #13232NaxosCG
CustomerIf you don’t mind, i’ll send you the wetransfer link in PM as the scene is quite (c) by my customer.
2019-03-25 at 1:26 pm #13233NaxosCG
CustomerOh it seams that this forum board does not allow us to send private messages…
Any email adress ?"1+1=3... for large values of 1"
2019-03-25 at 2:11 pm #13239Mikhail Luzyanin
StaffAny email adress ?
Sorry, it’s awailable only for customers. You can include in the file only part of the mesh and materials that has problems and attach it here.
2019-03-25 at 3:17 pm #13241NaxosCG
CustomerI’ll come back when i’ll be customer… I think it will be quite soon
2019-03-25 at 3:40 pm #13242Mikhail Luzyanin
StaffI’ll come back when i’ll be customer… I think it will be quite soon
Thats an awesome news
2019-03-25 at 4:25 pm #13246NaxosCG
CustomerIn the midtime i’ve optimized the object (it’s from a STEP file), and now it renders ok. (200 k polys)
Maybe too heavy scenes are hard to render properly ?
About becoming a customer, i have to make some more tests (and figure out how to put a html background that fits the 3D placement (see my babytest example : https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:056ac22648/applications/BabyTest/BabyTest.html ), and learn how to use html buttons / picture buttons to trigger stuff in the Verge3D scene.
I’m not a coder, this is my pain for that last 2 things, but i do understand algorythmic / logical stuff. And puzzles are good for me. the html part is the dark point.
regards
2019-03-25 at 4:26 pm #13247NaxosCG
Customerhttps://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:056ac22648/applications/HMS-test/HMS-test.html
200k polys test"1+1=3... for large values of 1"
2019-03-26 at 6:43 am #13257Mikhail Luzyanin
StaffIn the midtime i’ve optimized the object (it’s from a STEP file), and now it renders ok. (200 k polys)
Sometimes different errors may appear after importing geometry, so when you retopologied the mesh they may dissapear. There’s no problem to render more than 200k or even 2 milion, but it will be just slower.
The puzzle for now already very powerful tool to create most of the common used things that you can find in e-commerse 3d configurators and it’s possibilities grow fast each release of the enigne.
I’m not a coder too but I making all demos using Verge3D without any help/ from coders. To create a html page I use Webflow html visual editor it’s very comfortable easy and intuitive. I’ve tried a Google Web Designer, but I absolute dissatisfied with my result and you need to know site layout rules deep enough to with with it, and it has a trash interface (for my opinion). There’s also a lot of html visual editors but I can’t reccomend them because I haven’t tried them yet, but I will soon.
2019-03-26 at 9:43 am #13264NaxosCG
CustomerThank you for infos, i’ll give a try to Webflow.
2019-03-26 at 2:03 pm #13274NaxosCG
CustomerI’ve tried Webflow, it is simple and Wix-like, so i can handle that !
But, call me fool, i can’t find any way to save / download the created website, so i can replace in the applications folder for my Verge3D scenes…
What did i missed ? How can i use what i’ve made in Webflow with my Verge3D stuff ?
Regards
2019-03-26 at 2:28 pm #13277NaxosCG
CustomerI mean, in the video tut made by Yuri, he uses Google WD that can publish locally.
I can’t find this one in WebFlow."1+1=3... for large values of 1"
2019-03-26 at 2:33 pm #13279Mikhail Luzyanin
StaffWhat did i missed ? How can i use what i’ve made in Webflow with my Verge3D stuff ?
It’s only awailable when you bought a subscribtion.
