Home › Forums › Graphics / Blender › shadeless material
- This topic has 10 replies, 4 voices, and was last updated 6 years, 5 months ago by
Mikhail Luzyanin.
2018-10-12 at 2:17 pm #8181
jsteidele
Participanthere we go again:
I made a shadeless material setup (see attachment) and it worked for a while. Sometimes it just changes without my input
and it looks like this: https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:83ed0f2ff6/applications/TP_unit_verge3d/TP_unit_verge3d.html
the floor is weirdly grey and not 100% white. All face normals are facing inwards towards the content. Inverting just makes hidden objects below show up (backface culling on off didn’t help? Any ideas? or is there a specific verge 3D shadeless shader :P I also tried the shadeless shader which comes with -> “import images as planes” nada
2018-10-12 at 2:39 pm #8183Mikhail Luzyanin
StaffEmittion is the only way to get shadeless material in Cycles, but you used it with Light Path that will not work for the shaders, only for world and you also fixed it with null shader that will also cause unexpected result. To get pure shadeless effet use only emittion with strength 1 or mix it using texture, but with another shader for example Diffuse shader or something. Cycles nodes support still in progress, most of the nodes are not supported yet.
2018-10-12 at 2:54 pm #8185jsteidele
ParticipantI see thank you Mikhail.
Weird, SOMETIMES it worked.
2018-10-12 at 3:41 pm #8186jsteidele
Participantfound it. I enabled Ambient Occlusion in the ShadingsTab of the viewport. Disabling fixed it using the original node setup as in the image above. Hope it helps other people
2018-10-12 at 3:58 pm #8188Mikhail Luzyanin
StaffDisabling fixed with the node setup from above.
Hmm, I think it’s a bug, we’ll need to fix this.
2018-10-12 at 4:01 pm #8190brian.kumanchik
Customercan I see an example node setup with a texture – please!
2018-10-12 at 4:40 pm #8191jsteidele
ParticipantHey brian,
I am not sure if I understand correctly but the node setup which you can see attached to my original message is the one that works, no texture needed. If your idea was to control the colors of a shadeless mat. then just plug the texture into the “Color” socket of the emission shader . :)
2018-10-12 at 10:41 pm #8194brian.kumanchik
CustomerI wanted to put a texture on a plane (like a sign) and not have it affected by the light in the scene.
2018-10-13 at 3:38 pm #8207Mikhail Luzyanin
StaffUse pure emittion shader to get shadeless effect of the material.
2018-10-29 at 11:40 pm #8515Viktor.Rios
ParticipantShaderless, directly to output material in Blender will result in shadeless material in Verge3D publish?
2018-10-30 at 7:26 am #8516Mikhail Luzyanin
StaffShaderless, directly to output material in Blender will result in shadeless material in Verge3D publish?
You mean in Internal Render nodes? Then yes, but in Cycles you canno’t connect texture directly into output.
