Several events, same action targeted
Home Forums Puzzles Several events, same action targeted
  • #44456
    georgeslambert
    I have a long list of actions that are triggered by several events (html elements in parent doc and in objects in 3D window).
    Is there a way to avoid copy every actions in “on even” and “when clicked” puzzles? this takes alot of space… and generate alot of code, I assume.
    Thanx,
    Georges.
    #44457
    georgeslambert
    Aswel, I have to double eveything because of the tablet access “touchstart” instead of “click” for html elements in parent doc.
    In short, Is there a way to create a list of events triggering an action?
    #44461
    Hi Georges,
    yes, you can put your puzzles into a procedure
    which in turn, will be called by your events
    #44472
    georgeslambert
    Thanks Yuri, All clear! That’s taking the problem by the other end, but it solves it too! :good:
