Setting different colors for multiple objects
Home › Forums › Programming › Setting different colors for multiple objects
  • #26710
    web
    I’m wondering what is the best and most efficent way to set diffuse color for multiple objects programmatically.
    To be more precise:
    I got around 480-520 objects which are named unique. The all got the same material applied. After a certain user interaction I need to “group” these objects. Therefor I got an array with 4 different colors. These colors need to be applied to all the objects by their names. It is also necessary to apply the inital material after a certain user interaction.
    My current approach would be, to create 4 new materials (directly in js) with the different colors I need. And then apply each material to the appropriate object.
    When I dont need the colors anymore I would simply apply the intial material.
    Would this be the best way, or are there other approaches?
    #26720
    I think it should work well! :good:
    #26738
    web
    For the moment I created a new material for each object. Works so far.
    Just not sure if this will make the scene slow at some point, when this function is executed several times.
    #26787
    it’s ok to run this multiple times – it is a key to not perform heavy operations every frame
    #26920
    Xen Wildman
    You could also consider vertex color.
