Home › Forums › Graphics / Blender › Set transparency on material with node
- This topic has 12 replies, 3 voices, and was last updated 4 years, 9 months ago by
Mikhail Luzyanin.
2020-06-18 at 8:28 pm #28978
marshallus
CustomerHi, to begin thanks for the work you made on verge3d and puzzle.
I need your help, i’m working on a project to configure a cup with a logo on it.
I want the logo to be opaque, and the main color of the cup transparent (like 30%)
I want to control the opacity by value (i use a lot puzzle).
I cant make it work, someone can show me the right path?Thanks a lot !
2020-06-19 at 6:36 am #28983Mikhail Luzyanin
StaffHere’s an example for you it may be. You can shange Value using Puzzles to switch on\off transperecy of the object.
2020-06-21 at 8:14 pm #29033marshallus
CustomerHi thanks for answer.
Is-it possible to control opacity (like 0.5 for example)Thanks :)
2020-06-22 at 6:57 am #29059Mikhail Luzyanin
StaffIs-it possible to control opacity (like 0.5 for example)
Yes, but you need to set it to Alpha Blend type of the transperency instead of Alpha CLip.
2020-06-22 at 9:11 pm #29123marshallus
Customeri’m sorry i cant get what i want working.
I will try to explain better :
– the logo must be opaque, and it can have some colors on it
– the color or the cup can change, and the cup could be transparent and i want to control it
(i’m trying to make an old application i made in old blend4web version to verge3d)2020-06-23 at 3:18 am #29126GLiFTeK
CustomerHi
You might want to use translucency.
For either translucency or transparency use a png file with a transparent background, in an image texture.Start with a texture coordinates node (uv or object) to a mapping node to the image texture to the Fac of a mix texture node. Top input of the mix transparent or translucent then bottom one diffuse or emission… Then out to material output.
To control the amount of transparent then put an RGB into the transparent color socket then you can change its color and alpha
plz share Discord link & on your signature!2020-06-23 at 5:57 am #29138Mikhail Luzyanin
Staffi’m sorry i cant get what i want working.
– the color or the cup can change, and the cup could be transparent and i want to control itHere’s a correct file. Or if you want to get it on your example just share the file here I will correct it.
2020-06-23 at 7:29 pm #29184marshallus
Customerthanks for your help
I upload the file, i want to control opacity of the red part of the cup, logo must be opaque.Thanks again for your time
You must be logged in to view attached files.2020-06-24 at 6:13 am #29194Mikhail Luzyanin
StaffPlease attach logo1.png too.
2020-06-24 at 6:24 am #29196marshallus
Customer:) here
2020-06-24 at 6:48 am #29198Mikhail Luzyanin
StaffHere it is.
2020-06-24 at 7:01 am #29204marshallus
Customermy hero ! Any donate link somewhere to support you?
2020-06-24 at 7:10 am #29205Mikhail Luzyanin
StaffAny donate link somewhere to support you?
You already made a donation when you bought a license
. I’m a member of engine’s development team.
