- This topic has 5 replies, 2 voices, and was last updated 5 years, 5 months ago by
Yuri Kovelenov.
2019-08-28 at 7:54 am #18179
GLiFTeK
CustomerHi
I’ve been trying everything i can imagine to get this to work for the past 24 hrs.
I’ve got a series of 6 vertical, front facing discs in a radial formation on the Y,Xm axis.
i want to have them always facing “front” or “camera” as their “empty” null object spins.
I’m using Set Object Direction for all of them.
https://www.soft8soft.com/docs/manual/en/puzzles/Objects.html#set_object_direction
they hold a pose.. but that pose is held as they rotate around their mutual center (the slowly turning empty null)it’s a very simple setup.
i used the example in the manual for the camera.. no dice..
then i put an empty where i wanted them to face.. and used that as the “get” object in their puzzles instead of the camera.
newp.
mind you i have the turning empty parented to a second master empty.
though i’ve tried this with and without the second empty null.i’ve applied all my transforms..
can’t think of anything else..possibly something you could think of that would interfere with this function or disable it?
halpz?!
thnx.
plz share Discord link & on your signature!2019-08-28 at 8:49 am #18180Yuri Kovelenov
Staff2019-08-28 at 2:55 pm #18209GLiFTeK
Customerah! i just spent another 6 hours convinced i could figure it out… :(
tried “Locked Track” Constraints in Blender etc.. newp.. tried it without any nulls…. newp…here’s the zip of the project file.
i look forward to hearing form you.
super curious as to what it is.Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2019-08-28 at 3:24 pm #18212Yuri Kovelenov
StaffThe discs need to have origin in their centers to be able to rotate around themselves. Also, you can use the Locked Track constraint to automatically orient them towards the camera.
I fixed one disc for you.
You must be logged in to view attached files.2019-08-28 at 5:59 pm #18216GLiFTeK
Customerwow oh man.. i WAS using the Locked TRack constraint AND setting their origins to center of mass..(surface) .. BUT as i routinely do by force of habit.. i applied all transformations on them before exporting.. didn’t know that doing that, moved all their origins back to the global 0,0,0,.
thanks.. now back to the task at hand.
plz share Discord link & on your signature!2019-08-29 at 7:14 am #18236Yuri Kovelenov
Staff -
