Set material from project.js
Home Forums Programming Set material from project.js
  • #31742
    jortijn
    Hi All,
    I would like to set a material(defined in blender wood1, wood2, wood3) of an object(Cube) from the function prepareExternalInterface(app) as this gets called from my application when I change an input.
    I have an example that uses
    app.ExternalInterface.updateScene({“COLOR” : colorInputValue});
    however updateScene is not found
    I found this example
    obj.material = new v3d.MeshPhongMaterial({ color: ‘#00BB00’, emissive: ‘#550000’ });
    and that works but I want to set the material defined in Blender to an object(Cube)
    Am I on the wrong path here as I did see that I can call JS from puzzles not sure how I get the value back from the function prepareExternalInterface(app)
    Many thanks,
    Jortijn
    #31745
    please use the puzzle assign material, or, if you prefer programming, the code that this puzzle generates.
    #31746
    jortijn
    Hi Yuri,
    Thank you for your quick reply.
    As I get a JSON back from our application with an input value
    How do I pass this back to puzzle?
    my current function
    app.ExternalInterface.parse_selections = function (selections) {
    var colorInputValue = ( selections[‘COLOR’] != undefined ) ? selections[‘COLOR’] : ‘CHROME’ ;
    console.log(“colorInputValue” + colorInputValue);
    The color selection is right as I can see it in my logger I am not sure how I can get puzzle to trigger when parse_selections function is called and to pickup the JSON in the dictionary?
    I probably should add we had something like “when called from JS as” but I can’t find that in puzzle(See attachment).
    Many thanks,
    Jortijn
    #31750
    #31751
    jortijn
    Hi Yuri,
    Thank you! you pointed me in the right direction it works great now!
    for others(hope this is allowed)
    v3d.puzzles.procedures.cubeColor(colorInputValue);
    and for the puzzle see the image attached.
    Kind regards,
    Jortijn
    #31760
    glad it helped! :good:
